Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008 Focus Audio Wiring Diagram including Audiophile Setup
Old 09-08-2008, 03:32 AM   #11
wang
Fan#: 58974
What I Drive: 2008 Ice Blue Focus S
FF Reputation: 1 wang Good Standing Member
Originally Posted by dcorwin822 View Post
I'd like to correct you on this. In the trunk behind the d-side passenger there is a connector for the sub woofer on all the 08 focuses. The the only reason why we can't tap a woofer set up off of this on non-audiophile systems is because behind the head unit in the dash Ford cut off the harness and there is no 'spot' in the head unit to get a clean sub out. There has been a previous post about this 'issue' where I have posted pictures of the cut harness and lack of connector on the head unit for the appropriate connector if it was there.
So do you guys think it is possible to find that connector and just solder on that one part? If not then the only option, assuming we're using the stock HU, is to use a converter then =(
wang is offline
