Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008 Focus Audio Wiring Diagram including Audiophile Setup
Old 09-07-2008, 11:53 PM   #10
dcorwin822
dcorwin822's Avatar
Fan#: 53054
What I Drive: 2008 Vermillion Red SES
Points 18,519, Level 86
Points: 18,519, Level: 86 Points: 18,519, Level: 86 Points: 18,519, Level: 86
Level Up 34% Completed
FF Reputation: 11 dcorwin822 Great Standing Member
Originally Posted by kenzx3 View Post
It's a specialty harness designed to fit the Audiophile Sub setup only. It is not a set of RCA cables, and the wiring is not there on every '08 focus just as not every 00-07 focus came prewired. Some that have the harness but not audiophile setup are just lucky
I'd like to correct you on this. In the trunk behind the d-side passenger there is a connector for the sub woofer on all the 08 focuses. The the only reason why we can't tap a woofer set up off of this on non-audiophile systems is because behind the head unit in the dash Ford cut off the harness and there is no 'spot' in the head unit to get a clean sub out. There has been a previous post about this 'issue' where I have posted pictures of the cut harness and lack of connector on the head unit for the appropriate connector if it was there.
dcorwin822 is offline
