Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 08-30-2008, 07:42 PM   #18
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 110,270, Level 100
Points: 110,270, Level: 100 Points: 110,270, Level: 100 Points: 110,270, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
My situation was not just replacing the belt. I found my timing had actually jumped 30+ degrees when the timing belt ribs came off. So when I thought I was at TDC I actually wasn't.
The old belt was removed, I had the cam bar in place but once I removed the exhaust and installed the timing pin I was able to rotate the crank sprocket clockwise. You will know when you hit the pin. Anyway here's a pic of the 2 paint marks and the compass I put on the sprocket to show how far off it was.
I noted the number of teeth on the crank sprocket along with a 360* circle. As you can see each crank tooth is 18* of timing. Mine had jumped 2 teeth or 36* of timing.
lhc_focus is offline
