Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 08-29-2008, 12:01 AM   #10
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 84,226, Level 100
Points: 84,226, Level: 100 Points: 84,226, Level: 100 Points: 84,226, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
At this point I remove the front P side tire. Lugs are 19mm. Then I took out the wheel well cover. Again some take this out others don't, your call. I like easy. Tools needed are the T-25, phillips screwdriver and 8mm socket.
The lower front of the fender is the T-25.
There are 4 plastic type screws in the middle of the cover.
The 8mm holds up the back end just under the body.
Bag the parts and put this out the way.
lhc_focus is offline
