Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 08-27-2008, 11:40 PM   #7
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 110,270, Level 100
Points: 110,270, Level: 100 Points: 110,270, Level: 100 Points: 110,270, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
I moved the radiator resevior off to the side. The back side has a slit and slides down onto a tab. There is a 13mm bolt holding the tank to the fender. Use an extension to get it. I then used the pliers to move the hose clamps out of the way while tipping the tank back so I don't get wet. Then move the hoses out of the way. The plastic tank ended up in a bucket with small shreds of shop towel in the 3 holes to keep junk out. The first time around I also moved the power steering res too, but then learned it was not necessary. I put the 13mm bolt back into it's hole.
lhc_focus is offline
