Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 08-27-2008, 11:20 PM   #6
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 186,903, Level 100
Points: 186,903, Level: 100 Points: 186,903, Level: 100 Points: 186,903, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
Ok now to get the floor jack and some blocks of wood. I removed the P side motor mount and so motor needs to be supported. I used a large block on the jack so as not to damage the pan and helps take up space. Several pieces of short 2x4 will work too. Several times I needed to raise or lower the engine to get at the water pump and idler pulley. Again your choice I have read where others could do the same without all this. I like easy. Since I had other large chunks of wood, I stacked them under the transmission side just in case the jack slipped off the pan. I donít need any more repairs. Cinder blocks would work if you feel the same way. Your choice.
lhc_focus is offline
