Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - tried everything electrical problem on 05 ford focus need help
Old 08-20-2008, 05:40 PM   #8
Fan#: 51285
What I Drive: 2006,Blue,fx4
FF Reputation: 1 oddballish Good Standing Member
If the radio and clock are clearing it has to be a complete power disconnect. The clicking is probably a /or several relays going off / on when the power drops out and then back on.
Start at the battery connections, then where the cables are crimped / soldered to the cable connectors, and unfortunately the focus is notorious for its bad grounds. If none of these are bad check the loom in the tilt portion of the steering column for shorts / bare wires .
oddballish is offline
