Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO Install Shift Knob/Boot on ATX
Old 08-20-2008, 03:44 PM   #72
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Well I just did the shift boot mod only....using a boot from Auto Zone ($10). It's easy. Take the center consul out. The boot will slip over the knob without removing it. The boot has elastic on the bottom....just fits over the shifter bezel without removing anything. I installed a DIY foam gasket on the under-side of the consul opening.....to keep the consul from cutting into the boot. As you're re-installing the consul, pull the slack out of the boot around the opening...makes for a neat install.
You might have to put a small ring (maybe tape) of some sort on the shift lever to keep the boot from riding up too far. Easy install of about one hour, and you only need a phillips screw-driver.
bluefront is offline
