Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Safe DRL Foglight Mod
Old 08-17-2008, 11:03 PM   #2
Fan#: 58269
What I Drive: 2006 ZX4
FF Reputation: 4 oldpunk78 Good Standing Member
ops...^ i didn't read that very carefully
if you want to bypass the relay and not worry about the jumper, just put in a toggle and fuse, then:
i would think that all you'd need to do is pull out the oem wires and put in some heavier gauge stuff and solder all the connections possible. that should get the resistance down low enough that melting anything "shouldn't" be a problem. may be even a better ground too.
oldpunk78 is offline
