Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: Focus MTX-75 Duratec clutch, Phantom Grip, and Poly mount install
Old 06-20-2008, 09:57 AM   #10
sutyak
sutyak's Avatar
Fan#: 12724
What I Drive: Turbo 04 DSG Mach 1
Points 15,350, Level 79
Points: 15,350, Level: 79 Points: 15,350, Level: 79 Points: 15,350, Level: 79
Level Up 50% Completed
FF Reputation: 62 sutyak Excellent Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by HyBalz View Post
How much material did you need to remove from the spider gears? Did you change final drive gear ratio? You didn't say why you removed the ring gear.
Not much material needed to be removed. Maybe .02" from each.
I purchased a second stock differential so I could have the PG installed before I even started the project.
That way the only thing required would be swapping the ring gear from my stock diff onto the one with the PG installed.
Also, about holding the ring gear in the vise: that ring gear is a beast. Holding it in the vise for a few minutes won't hurt it at all.
mark
'04 Mach 1. Built. Turbo. 667whp/631wtq
'06 Focus. Built. Turbo. WMI. (sold)
'03 Mach 1 : 12.61 @ 106.59 (sold)
sutyak is offline
