Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sun Hyper Ground Kit Installed
Old 06-19-2008, 08:47 PM   #35
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
Originally Posted by iminhell View Post
Brad, Do me a favor. Go to a run that is about a foot long and measure the resistance in Ohms. Most likely if you test what you have and various other brands they will be fairly close, as in close enough to not register as different on a normal DVOM.
OK so I finally got my trusty Craftsman VM out and read the instructions on how to measure resistance (told you I wasn't an electronics genius)
Here's what I did. Disconnected the new ground cable from main chassis ground location. Measured resistance from main chassis ground (with stock ground cable only in place) to a bolt that a ground wire coming out of the wiring harness is attached to the chassis with. Meter read 1.1
Re-connected new ground cable to main chassis ground. Same measurement points. This time the meter read .5. Did this several times, same results. Also checked several other locations throughout the engine and under the hood in general. Same .5 reading. So I either did it wrong, or the new ground cables would appear to reduce the resistance by 50%.
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
