Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is this a good wheel/tire choice for G stock/STN
Old 06-16-2008, 10:06 PM   #20
Fan#: 52755
What I Drive: 2003 SVTF
FF Reputation: 1 Killercanary Good Standing Member
Dirtydeeds- Thanks, I'll try that next time out. The only reason I'm running them so high is because even at 44-46lbs up front, the side walls show scuff signs. I will try it though.
Originally Posted by WeeAsp View Post
Also, check your pressures after each run.
Pressures increase as the tire temp increases.
So, you may start at 40LBS, but after your run be over 50.
Thanks! I do check it after every run, and you are right, it goes up 1-2lbs every run. If I do have to wet the tires, should I wet them and then check the air, or doesn't it really matter?
My DD- 2003 SVTF
My toys-'95 Mustang GT 'vert/'94 Cobra autocross car
Wife's toy- 2000 MR2 Spyder
Family vehicle- 2007 Infiniti G35X
Killercanary is offline
