Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sun Hyper Ground Kit Installed
Old 06-16-2008, 12:05 PM   #26
kimbo305
kimbo305's Avatar
Fan#: 52390
What I Drive: '00 Zetec ZX3
Points 3,326, Level 35
Points: 3,326, Level: 35 Points: 3,326, Level: 35 Points: 3,326, Level: 35
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 12 kimbo305 Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by BradWhite View Post
Isn't this the same type of shielding we're referring to regarding these cables?
I'm not trying to argue with you, believe me my knowledge level of automotive wiring is worse than a two years olds. But shielding, as described above, make sense to me.
Yes, that is shielding, but if the wire you're using as the shield is grounded to the car ground, then it's going to experience the same noises as the ground. So if the ground sees a spike, the shield will see the spike too, since they would be at the same potential to each other at all times. Thus, the shield is not truly electrically isolated from the ground wire it's supposed to protect. It would be effective for high frequency noise, but not all types of noise.
In theory, you could wire the ground shield to the earth by dragging a wire on the ground and attaching the ground shield to that. But who would do that? :)
check out my Fiesta Movement entry: youtube.com/watch?v=dXY3mi1NWeg&eurl=http://www.focusfanatics.com
I wholeheartedly endorse McNew's for installing and tuning your Focus.
kimbo305 is offline
