Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO: Mechanical CEL Fix for a Header
Old 06-02-2008, 07:29 PM   #43
gokart2
Fan#: 31234
What I Drive: 2006 Silver ST w/SAP#1
Points 3,041, Level 33
Points: 3,041, Level: 33 Points: 3,041, Level: 33 Points: 3,041, Level: 33
Level Up 94% Completed
Forum Activity 4%
FF Reputation: 14 gokart2 Great Standing Member
Heating up the exhaust will help, but may cause you to kill the threads in the bung. But.... get it hot, then use a 02 socket if possible (if not a 21mm is better fit then a 7/8 wrench), try to loosen it up a bit, but once it starts seizing again stop. Spray WD-40 (TAP MAGIC is by far the best stuff in the world for penatrating oil) onto the threads, then tighten it back up. Not too tight though. Then loosen again, spray the threads, tighten....keep doing that. After a few trys, it should come out. We use these sensors at work all the time, but we put anti-seize on them even though Ford puts a tiny speck on them. You should only need to get the sensor/bung warm for the initial break loose.
ST Crew #90
My wife--->
<----Me
gokart2 is offline
