Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO: Mechanical CEL Fix for a Header
Old 06-02-2008, 06:54 PM   #42
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,073, Level 100
Points: 33,073, Level: 100 Points: 33,073, Level: 100 Points: 33,073, Level: 100
Forum Activity 71%
Activity: 71% Activity: 71% Activity: 71%
Originally Posted by homeboyjames View Post
dammit i rounded the nut on the bottom 02 sensor cant get it out ... guess im going to have to pull the fing header back out..... man this just makes my g day ive never been so g pissed off
So nobody else has this problem: First off using an O2 sensor socket is the best idea instead of a 12 pt or box end of a wrench. That's of minor importance compared to the loosening trick. Heat will loosen things up for you. Wear leather gloves and a long sleeve shirt, and run the engine to loosen the stubborn O2 sensor. Once it's hot, get back under there and it will break loose- be careful not to get burned! I've had to use this trick on many a repair after a DIY job.
I hope that helps someone in the future. Sorry I didn't see this sooner.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
