Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to Remove 08 Sedan Grille / Headlight
Old 05-25-2008, 04:43 AM   #1
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
Cool How to Remove 08 Sedan Grille / Headlight
Maybe it's just me or there's some trick that I don't know, but removing a headlight from an 08 Sedan, per the owners manual instructions, is simply a lesson in frustration. And you have to completely remove the headlight to get to the bulbs. I now get the grille out of the way, a 5 minute job, and save myself a lot of grief.
To remove the grille, remove the four (4) plastic expansion plugs (blue circles). After removing the plugs pull up to release the alignment tabs (red circles).
While holding the top of the grille up look inside at the bottom, you will find one more expansion plug (blue circle) on each side, remove those. There is also a catch on the grille that hooks onto the bumper (red circle) on each side. Push in on the grill, push down on the bumper close to the grille catch and release the grille. If you did it right the catch should be released. You might have to try a couple times to get the hang of it. Also note the four alignment slots for re-installation, two on each side (yellow circles).
That's it, once those catches are released the grille should slid right out.
Now you can remove all three bolts from the headlight (blue circles), pull it clear of the fender and up to release that enormous tab on the bottom of it. And you can do it all without swearing or a cutting torch!
All I know is that if I'm doing anything with a headlight, my grille comes off first!
To put the grille back in, start from the bottom and slide it into those four alignment slots, replace the lower expansion plugs, push the top in and get the two top alignment tabs in place then replace the four top expansion plugs. Your done. That is assuming you remembered to re-install the headlight first. Which according to the owners manual can be done with the grille in place, but hey - good luck with that.
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
