Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is this a good wheel/tire choice for G stock/STN
Old 05-14-2008, 04:27 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
^^^You can run whatever tire size you want...
As long as it fits on the stock wheel size.
There are no tire size requirements, just wheels.
Here's the rule:
13.4 WHEELS
Any type wheel may be used provided it complies with the following:
it is the same width and diameter as standard, and as installed (including wheel spacers if applicable)
it does not have an offsetmore than +/- 0.25 inch from a standard wheel for the car.
The resultant change in track dimensions is allowed.
Auto-X-ZTS has a great suggestion for the size.
The shorter gearing is a definite help on the SVTF.
Not only that, you've just effectively lowered your center of gravity by almost 1/2" by running the 40 series.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
