Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - spring noise from front suspension after coil change
Old 05-12-2008, 06:04 PM   #6
Fan#: 52304
What I Drive: 2002 Focus SE
FF Reputation: 1 siffleu Good Standing Member
Originally Posted by jetrinka View Post
Check the swaybar endlinks to see if they are tight.
I've done all of the above
the rubber on the swaybar endlink are worn on both side
is this can cause the "squeee squee rust spring like sound"
the sound can be hear by just adding weight into the car so I did the test with a helper and put my hand on the endlink and I was able to feel the vibration of the sound into the endlink
is worn, cracked rubbers of endlink can cause this annoying noise ?
siffleu is offline
