Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Key Fob Programming How-To
Old 04-27-2008, 05:07 PM   #1
WitchCitySVT
Turbo!!!!
WitchCitySVT's Avatar
Fan#: 33699
What I Drive: 2012 Chevy Sonic 1.4 Turbo LTZ
FF Reputation: 30 WitchCitySVT Great Standing Member
I found this on another site. It's use full if you have to get a new Key Fob or change the battery in your current one.
Radio Frequency Programming Instructions:
1. Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds. The car makes a noise that is the same noise i get when i open the door and leave the lights on.
2. Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds. A red warning system LED (By the clock) stays on continuously to indicate this if you have an LED. I don't have an LED so i just guessed it was in learn mode.
3. During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED. No indication is given if you don't have the LED.
4. Wait until learn mode times out (20 seconds) or switch the ignition back to ON. I just put the key in the ignition and started the car.
HEY PRESTO ALL WORKS FINE NOW!!!
BUILD# 840 out of 3985 BUILD DATE 4/1/2003 *RIP*
2003 Competition Orange SVT *Revived*
2012 Black Sonic 1.4 Turbo LTZ
WitchCitySVT is offline
