Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cruise control
Thread: Cruise control
Old 04-19-2008, 07:51 PM   #6
kb65
Fan#: 55347
What I Drive: 06 focus,90 mustang conv,98 expedit
FF Reputation: 1 kb65 Good Standing Member
If you follow mjmallon he has it all correct. On my 06 all of the wires under the dash were there. I had to add the brake switch and change the clutch switch. Add the cruise switch ( clock spring was ok) and I was done inside. Also while you are in the column the wires are also there for the radio controls just plug it in.
Now for under the hood. You will need the servo and cable and the headlight harness. Try to get one from a car with fog lights in case you want to add those as all of the dash wires for the fogs is also there just add the switch. To change the harness you will need to remove the left wheel well cover. If you can get the parts it is not a bad job. pretty much plug and play. It works for me. good luck.
Ken,
kb65 is offline
