Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tire recommendations for stock 16" wheels for autocross
Old 04-15-2008, 11:57 PM   #6
SVT Robzor
SVT Robzor's Avatar
Fan#: 26230
What I Drive: 2004 CD Silver SVT
FF Reputation: 5 SVT Robzor Good Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by Auto-X-ZTS View Post
Dunlop makes a 205/50-16 for the Z1...its 24.1" (close to OE diameter)
The RT615 Falkens also come in a 215/45-16...its 23.5"
The B-Stone RE01 is a 205/45-16...and is about 23.2"
The shorter tires will give better gearing. The Dunlop and the B-Stone will out-grip the Falken. The Falken is cheap, the Z1 a bit more. Pick your poison...they'll work OK.
Because the Focus, especially the SVT, likes the shorter tire for gearing, I suspect the B-Stone would be fastest.
Ditto'd and +1 on all counts. The Z1 is looking like a very fast new tire; it supposedly has both a compound nearly as grippy as the Yoko Advan Neova, which are $$$.$$, and a much more rigid structure than the 'stones, which is a benefit for camber-challenged, nose heavy cars like ours. The RT-615 is a standby, and the 215/45 would be a great way to go. So would the stone, which may be less of a pinch on the 6" rim, and so would be Z1, though those are said to run super-wide for their called size.
No real bad way to go with those, just understand you're not buying a long wearing street tire. The BFG G-force Sport, or maybe a General Exclaim UHP or similar tire might be a better call if you don't plan on quite as much dedication. It can also be better to learn to be fast with a less grippy setup, you won't waste a stickier setup later that way.
EDIT: on tire size, I've long read that while pinching a wide tire is NOT optimal, at day's end the wider tire is almost ALWAYS faster. If you have unlimited realestate, then a square or slight stretched fit should be quicker. Since you dont have that in stock class, the widest tire will, all other thing being equal, be faster.
2004 SVT Focus
Custom front-bumper-mount bug guts; precision sprayed brake dust on OEM rims; 15% Pine Tree pollen over the clear coat.
No more SVT autocross, I drive the thing in the avatar.
SVT Robzor is offline
