Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus Rear Tire Wear - Camber Bolts or Control Arms?
Old 04-05-2008, 05:32 PM   #9
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,640, Level 78
Points: 14,640, Level: 78 Points: 14,640, Level: 78 Points: 14,640, Level: 78
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 90 goinloco1 Excellent Standing Member
there is an easier and cheaper way to kill both birds. both of my cars have had this done with no problems what so ever over 45,000 miles combined.
pop the rear hub loose from the lower control arm. elongate the holes the bushing bolt goes through by about 3/8"-1/2" toward the center of the car on both lower control arms.assemble loosely and push the bottom of the hub toward the center of the car. this will take the camber out of it and some of the toe. the rest of the toe can be done with the toe adjustment. torque to specs and your set. i did find on lowered cars camber bolts will still be needed, but this gives alot more adjustment range.
or for a couple hundred buy the ford racing adjustable subframe.
goinloco1 is offline
