Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - PCV Valve on teh SPI.. - finally found it.
Old 06-17-2004, 06:10 PM   #1
Fan#: 2381
What I Drive: 2000 Gold Focus LX Sedan
FF Reputation: 1 The_good_guy Good Standing Member
It took a while, but I finally found the PCV valve on the SPI.
If you got to get a new valve, dont go to autozone or pepboys or whatever, they dont have the part on their computers.. I looked.
The motorcraft part number for the SPI is EV-262.
Atleast that is what it was for my 2000 SPI.
Now the stock PCV valve looks different from the motorcraft replacement. The old valve has a nice triangular cover on both sides on the inside (sorta like a shield i would say.. its kinda weird) but the new one is open on the inside. However this is the part and i checked with galpin ford. It might look differnet.. but its the part.
My stock part was working alright (i shook it and it rattles) but i decided to replace the valve just in case - i was trying to track down this weird vibration on my car during idle.. basically a rough idle.
WARNING: Make sure you check your rubber hose that goes from the PCV valve to the Intake.. I have to replace mine - the rubber is worn out and is colapseing when I start the engine.
To find the SPI PCV valve, look on your valve cover. On the left side of the valve cover is a tube, this IS NOT your PCV valve , though you would assume it to be. This runs to the PCV filter / Breather filter inside your stock airbox.
The actual PCV valve is on the top right of the valve cover. If you look at your oil filler hole, go north from there on the valve cover and then go east. You will run into it. It is covered under the other tube that runs from the other side of the valve cover. Basically its on the top right side of your valve cover. You will find it.
To take it off:
1) Detach the PCV hose from the PCV valve. Should be a large hose going to the intake manifold.
2) Rotate the PCV valve counterclockwise.
3) Pull the PCV valve from the valve cover.
4) To install, reverse the removal procedure.
I highly suggest checking that tube that runs from the PCV valve to the intake.. I have to now replace that bloody tube... I just happened to check before installing my PCV valve and noticed that the tube shrinks when i start the engine.. it shouldnt shrink..
Actually check all your tubes.. to make sure nothing is cracked and stuff..
I got 69K on mine, and I just replaced teh PCV valve, i dont know when it was to be replaced, or if it needed replacing, but i went ahead just in case.
The_good_guy is offline
