Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Drag race the ATX with Nitrous?! HELP?!
Old 03-06-2008, 12:00 AM   #3
blackoutSVT
Lurking
blackoutSVT's Avatar
Fan#: 52102
What I Drive: 86 sportster1100, 12 Focus SE Sedan
FF Reputation: 9 blackoutSVT Good Standing Member
Buy-Sell-Trade Rating: (15)
well i can give you some advice.. first off don't spray off the line. hit it about mid track you don't have a drag car per say the only time nitrous is good off the line is when you are running slicks. i would also be careful putting slicks on your focus with out changing out the Differential. could snap the one you got on it... if you are having trubble getting traction try heating your tires in the water trap if they will let you or bring a portable torch with you but if you go that rout be careful of that don't want to blow out your tire.lol the goal is to heat your tires up so they kinda melt a little so you will get better traction. but no need to lower the amount of nitrous you are using just don't spray off the ling and you should be gold.
blackoutSVT is offline
