Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lentech install with pics
Old 03-03-2008, 05:06 AM   #32
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,910, Level 26
Points: 1,910, Level: 26 Points: 1,910, Level: 26 Points: 1,910, Level: 26
Level Up 10% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by BOOSTA View Post
what exactly does a valve body do just curious?? and how much did it cost you to get??
They run around $700 last time I looked.
My amateur analysis is that what a valve body does is pump the transmission fluid to control the clutches in the ATX. The improved valve body will pump the fluid at a higher pressure and give you firmer shifts. This will compensate somewhat for the slippage that can come from increasing your motor's torque.
You can get a similar effect by adjusting this through your ECU as with a chip flasher but in my experience it only lasts a short time until the ECU adjusts to your driving habits.
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
