Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - AWD Zetec/SVT Focus INFO thread
Old 02-25-2008, 03:32 AM   #126
Bvtt_Whiper
Fan#: 52341
What I Drive: 2005, Blazing copper, focus.
FF Reputation: 1 Bvtt_Whiper Good Standing Member
Originally Posted by uk-v8-focus View Post
If all the previous information is correct;
Input to Transfer box is the same speed as to the front right wheel.
The Transfer box has no reduction (1:1).
Then you cannot use a conventional reduction diff as used on 8.8.
You can only use the Jag rear end, which will be 1:1, same speed in as speed out.
If you also look at my earlier post, the transfer box output to the rear turns the opposite way to a normal trans output, so the Jag rear IS the only one you can use.
(The system, branded "Traction-4" by Jaguar, utilises a unique Visteon design that drives the rear differential "backwards." )
So? Cryo treat a jag rear diff and get custom axles.
Bvtt_Whiper is offline
