Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - help gears screwed up?!?!
Old 02-18-2008, 11:27 AM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Adjusting the Cables
Here:
From FF member COSDEVSVT:
Originally Posted by COSDEVSVT View Post
Adjusting the linkage is easy:
1. Put the shifter in neutral
2. Carefully pop/pry up the orange lock on the back of the cable end
3. Wiggle the shifter around trying to find the best center position - don't shift into a gear
4. Push in the orange lock on the back of the cable end
Take it out for a test drive and see how all the gear gates feel.
Adjust if necessary again (likely won't need to).
Sometimes the cable housings come out of the body attachment clips (under the heat shielding in the 'tunnel') and can flop around a bit ... requiring a cable adjustment.
Some early-build SVTs had the MTX-style cable ends (as shown in the Focushacks article).
Newer builds have a cable end where the lock pops out instead of in (as shown in my earlier posted pic).
And, here's his other post with a pic:
http://www.focusfanatics.com/forum/s...9&#post1101019
WD40 Reverend GripShift - FF Moderator
WD40 is offline
