Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Air horns installed. Pictures and tips.
Old 06-06-2004, 06:33 PM   #47
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
Points 4,530, Level 42
Points: 4,530, Level: 42 Points: 4,530, Level: 42 Points: 4,530, Level: 42
Level Up 90% Completed
FF Reputation: 1 DidHeFocus? Good Standing Member
A dual-tone horn sounds much better to me because it forms a musical chord, rather than just a beep. As far as the acoustical physics of adding two horns output together, I would guess it is similar to audio formulas that I am familiar with. Doubling the audio power to a speaker will raise the output 3 db. Putting 2 speakers together playing the same signal should yield the same 3 db boost. Two horns should be the same as two speakers as far as output levels are concerned. Since the two horns will be playing different frequency tones, I don't know if the same thing holds true.
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
