Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove 2008 Ford Focus Radio
Old 01-27-2008, 04:03 PM   #1
Fan#: 52926
What I Drive: 2008 Black SES
FF Reputation: 1 Twinkeethekid Good Standing Member
I made a post in an earlier thread that I successfully was able to remove the radio unit in my 2008 Ford Focus and some people wanted to see pictures on how I did this. If you've seen the 2008 Focus's dash unit you know it looks pretty intimidating to remove. After playing around a bit I was able to remove it with no special "DIN tools." The only thing you'll need is a flathead screwdriver, a 7mm ratchet wrench, and a little bit of carefulness and patience.
1) You want to start off by pulling the e-brake all the way up as far as you can. I also found it helps to put the key in the ignition (you don't need to start it) and put your automatic transmission into D or L. This will just make it easier when you pull off the plastic that surround it.
2). Open the middle storage compartment and pry the plastic up with a flathead screwdriver (see picture below).
3) Once you remove the center plastic that surrounds the e-brake and shift stick you need to remove the 2 screws that secure the bottom of the radio unit into place (please see the below picture).
4) Using a flathead screwdriver pry the plastic plate on the passenger side (where the airbag is located). This won't come all the way off, as there's a screw keeping it from doing so. You should be able to to get it off enough to be able to remove the radio.
5) Remove the two screws holding the plastic that surrounds the steering wheel.
6) Lower the steering wheel all the way and remove this plastic.
7) Remove the vents above the top of the radio dash unit.
8) Remove the two screws holding the radio in place.
9) Starting from the bottom begin to pull the dash unit out.
I hope this helps for anyone who wants to try this. I apologize for not knowing technical words for things or for my lack of explanations. I hope the pictures speak pretty much for themselves. Good luck!
Twinkeethekid is offline
