Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Aftermarket radio wiring with stock SVT sub and amp.
Old 01-24-2008, 12:16 AM   #1
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: .
Points 17,247, Level 83
Points: 17,247, Level: 83 Points: 17,247, Level: 83 Points: 17,247, Level: 83
Level Up 80% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
Hey, just wanted to post this up for all of you svt guys, helped out another member on here with this wiring.
If you want to replace the audio-pile with an aftermarket, but want to retain the stock sub, follow this wiring and you should be all set
When installing a deck in a 2003 Focus SVT I was able to integrate the factory sub amp using the extra 7 pin plug from behind the factory radio. the wiring in the plug is as follows:
white/green-
yellow/brown-
white/red- amp turn on (6volts)
white/black- column control(resistance)
brown/yellow- column control (power)
white/black- pre amp output (+)
grey/black- pre amp output (-)
I used a 249 OHM resistor to drop the amp turn on (white/red)voltage so that the sub doesn't pop when the radio is turned on/off. Using a male RCA connector, you can wire into the low level factory input wiring (white/black,grey/black) so that it will accept the female sub output on the aftermarket radio.
Make sure that the new deck has an adjustable/low-pass sub out, or you will need an adjustable crossover. Good luck, and have fun!!
Step 1:
Cut the RCA cable in half and strip it like this: The white area is the positive and the other area is negative.
Step 2:
Cut two 1-foot (1 Red, 1 Black) of 16-gauge wire and connect it to the spliced RCA wires from Step 1. Red with positive and black with negative. Note that the RCA end will plug into the sub output from your receiver.
Step 3:
Cut another 1-foot of 16-gauge BLUE wire and connect it to the red and white wire. This wire is for the remote (turns your amp on and off with the ignition position).
Step 4:
Cut another 1-foot of 16-gauge RED wire and connect it to the black and white wire. This wire is for the positive sound input.
Step 5:
Cut another 1-foot of 16-gauge BLACK wire and connect it to the black and grey wire. This wire is for the negative sound input.
Step 6:
Now you would connect the Red & Black wires together from Step 2 to Step 4 & Step 5. (Which completes the sound inputs)
Step 7:
The BLUE wire from Step 3 needs to be connected to the remote switch wire from your deck (This color varies depending on your head unit model, consult your owner's manual). If you get a popping noise then you will need to install Resistor between the two to lesson the load.
MattZX3 is offline
