Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Engine stumble - SOLVED
Old 01-23-2008, 05:41 PM   #82
Fan#: 20612
What I Drive: 2000 sedan z-tech
FF Reputation: 1 andrewnico Good Standing Member
I had the same code p0171 and the auto trans was shifting bad,jumping in to gear when downshifting and I found the problem was a loose band clamp on the intake between the air filter and intake right on top and easy to get to. It works fine now. Wow that could have cost a lot if I went to a transmission shop !!!
Change the oil- fill the tires - and drive it till it breaks-thats my idea cuz if you take it in for work you will pay more than the car is worth over the years.
andrewnico is offline
