Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - help w/ installing OEM fog lights&dome light-new question!
Old 01-19-2008, 04:52 PM   #3
smoknblackzx3
smoknblackzx3's Avatar
Fan#: 49525
What I Drive: 2003 Pitch Black ZX3
FF Reputation: 1 smoknblackzx3 Good Standing Member
I'm not familliar with the '04 mounting, are these the triangle shaped lights that fit in the corners of the lower grille?
On my '03 the prong and clip go into the stock fog grille to hold the light housing in and the wiring plugs directly into the lamp. I was fortunate that the lights I received from a member had the mounts on them and I American engineered them into the proper place.
I'm still looking for a stock fogs grille to replace the non fog grille that I engineered to fit.
The relay location is in your owners manual, or should be . . . If you do the DRL mod you won't need the relay. They are about $8 +- so you might get one incase the local popo don't like your DRL in the fog position or you decide you don't like it. The switch is plug and play, a simple part exchange.
Good luck
Rich
The memories of a man in his old age are the deeds of a man in his prime . . .
http://www.cardomain.com/ride/2534007
smoknblackzx3 is offline
