Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - curbs and alignment NEED HELP
Old 01-11-2008, 12:43 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 226,961, Level 100
Points: 226,961, Level: 100 Points: 226,961, Level: 100 Points: 226,961, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Merged duplicate threads.
As far as alignment settings, have them set the toe to the minimum settings as shown in the specs.
Camber is virtually non-adjustable on these cars.
What little is available, again, have them set it at the minimum as shown in the specs.
The above is primarily to eliminate any tire wear issues, while preserving the excellent handling capabilities of the car.
Though...as you found out, take it easy in the snow.
But...First...have them do a decent check on all vital front end components to make sure nothing is bent or damaged.
You may also pull your wheel off and have it checked to see if it's bent or not.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
