Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Spec Focus Build - what does it cost
Old 11-28-2007, 06:14 PM   #19
LCR
FF Affiliate
Fan#: 36358
What I Drive: 2002 Gray Sedan
Points 1,228, Level 19
Points: 1,228, Level: 19 Points: 1,228, Level: 19 Points: 1,228, Level: 19
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
FF Reputation: 5 LCR Good Standing Member
Originally Posted by walshka07 View Post
how different are the wiring harnesses from the 2.3 to the 2.0? i figured the swap would be straight forward, but you talk about the wiring like its hell... how much of the 2.0s harness could i use? also would i have to change ECU's or could i just flash the engine to run a 2.3? also tuning is allowed, do you need a flasher of some sort? like my WRX you can just flash the stock ECU without a tuner/flasher... can you do the same with the foucs ECU? i have a bunch of questions if you can tell... ive got a lot more if you dont mind
Matt
The 2.0 Duratec and the 2.3 Duratec harnesses are interchangable. I have been going 2.0 to 2.3 back and forth all year in the same car. I keep 2 ecu's 1 2.3 and 2.0
Ford Racing Performance Parts
" Quitters Never Win "
LCR is offline
