Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus Competition Tires: Info, Links, and Reviews
Old 11-09-2007, 08:29 AM   #16
MattMarks
Fan#: 46203
What I Drive: 2005 ZX 4 ST Spec Focus
FF Reputation: 1 MattMarks Good Standing Member
THis is a bit of a cross-post, but Spec Focus is moving from the Toyo RA1 (205/40/17 to the Toyo R888 (215/45/17) for 2008. The RA1's are being phased out by the end of the year.
For more information -see the Road Racing and Rally forum.
More information on the R888
R888's Stats
Tire Size: 215/45ZR17 91W RD
Product Code: 168160
Rim Width: 7.0-8.0
Tire Wt: 22 lbs
Tread Depth: 6
Inflated Dimension (Dia): 24.6
Inflated Dimension (Width): 8.5
Static Loaded Radius: 11.5
Max Load: 1,356lbs
Max PSI: 50 PSI
Revs Per Mile: 846
Operating Temperature: 140F to 220F, optimum around 200F
Recommended Hot Inflation Pressures: High 30s to Low 40s (psi)
Spec Focus Test Stats:
Circumference at 34psi: 78.50
Diameter at 34psi: 24.64
Tread Depth: Full @ 6/32
2007 Spec Focus NASA National Championships - 4th place
2007 NASA Mid-Atlantic Spec Focus Champion
2006 NASA Mid-Atlantic 944 Supercup Champion
Spec Focus Advisory Board - Have a Spec Focus Question? Ask me!
MattMarks is offline
