Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear Sway Bar Install
Old 11-07-2007, 02:20 PM   #3
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,246, Level 61
Points: 8,246, Level: 61 Points: 8,246, Level: 61 Points: 8,246, Level: 61
Level Up 32% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
I also have a 2005 ZX3 S, which did not come with a rear sway bar. Steeda sells a kit that will allow you to bolt up their sway bar. I believe it's a 21mm bar as well.
Or, you could get the aluminum sway bar clamps that BiscuitNinja sells and use whatever rear bar you want. Make sure that the bar comes w/ the hardware to mount it though, otherwise you will have to get the endlink separately.
Personally, my setup is the BiscuitNinja aluminum clamps w/ the Saner/Auto-X ZTS 24mm adjustable rear swaybar. Total cost was around $250. Steeda's kit is about $150, but its not as beefy. Your choice.
BTW, this should be in the suspension section.
SYZ is offline
