Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Weighed my car yesterday......
Old 10-22-2007, 12:28 AM   #17
pelotonracer2
pelotonracer2's Avatar
Fan#: 49917
What I Drive: 2014 Ford Fiesta ST
Points 3,015, Level 33
Points: 3,015, Level: 33 Points: 3,015, Level: 33 Points: 3,015, Level: 33
Level Up 77% Completed
FF Reputation: 17 pelotonracer2 Great Standing Member
Here's a few questions to ponder!
So... considering a car that weighes 2,683-ish pounds and has 170 hp... the power to weight ratio is 15.78 pounds per hp. A VW GTI weighes 3170 (base, with no options) and comes out to 15.85 pounds per hp. Granted, it has 207 pft of torque (at the engine), but the hp is very close. Why is the SVT so much slower than cars with poorer power to weight ratios??? I'm guessing the lack of torque really hurts the SVT as well as inferior gearing.
Here's where I am going with this....
I plan on taking as much weight out of my '03 SVT as it is humanly possible. I'll buy another SVT as my daily commuter.
I'll get a FULL carbon fiber hood, OEM look carbon fiber front fenders, carbon fiber rear hatch, carbon fiber rear wing, remove the back seats, rear seat belts and mechanisms, replace the front seats with lighter racing style seats, install a 7 pound Braille battery, remove the spare, jack and stereo unit, speakers, wiring harnesses etc... remove the power window motors and replace with standard Focus ZX3 window cranks, remove most of the interior including any sound deadner, remove A/C compressor and set up a custom idler pulley, remove HVAC unit, install lighter crank pulley, install aluminum flywheel and Centerforce clutch, install ORP, find the lightest exhaust system on the market, I have 18" OZ Ulteggera wheels that weigh 16.5 pounds each and will couple them with lightweight (19.5 pound per) 215/35-18 tires and remove anything else that's not absolutely needed.... I'll also remove the sunroof glass and motor and replace it with a custon carbon plate.
How much, realistically do you think I could get rid of weightwise doing the above? I realize that's ALOT of work but I would also expect to remove a significan't amount of weight. As far as increasing the power a little, I want to stay NA and plan on Toms tune, SRI, 67mm throttlebody, underdrive pulleys, lightweight exhaust system, MSD coil with wires, new copper plugs, ORP and that's about it. I might consider stroking or big bore kit if it were possible to without robbing a bank AND it could be reliable with the right tuning.
For better handling I'll lower the car some (springs and shocks/struts), add some chassis bracing, install bigger roll bars front and rear, R&R all the motor mounts with better/stiffer ones, install short shifter, remove heat shields...
I'm curious to how removing weight and lightly increasing engine power a little using this platform... will have effect on performance... straight line acceleration AND handling.
Please share your thoughts and ideas...
pelotonracer2 is offline
