Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "The Official/Unofficial SVT Header Conversion Guide"
Old 10-14-2007, 01:29 AM   #32
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 9,671, Level 66
Points: 9,671, Level: 66 Points: 9,671, Level: 66 Points: 9,671, Level: 66
Level Up 6% Completed
FF Reputation: 17 svtguy88 Great Standing Member
If you aren't reusing the pipe, which you shouldn't be, you can cut it. However, depending on the bolt, you may be able to just slide the fitting apart (assuming the rest of the bolts on that flange came off okay).
If that doesn't work, go to the tried and true method. Grab a drill and a good bit, and drill the old bolt out of the hole
svtguy88 is offline
