Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - sporadic's Turbo Duratec build thread
Old 09-03-2007, 01:09 AM   #86
sutyak
sutyak's Avatar
Fan#: 12724
What I Drive: Turbo 04 DSG Mach 1
Points 15,704, Level 80
Points: 15,704, Level: 80 Points: 15,704, Level: 80 Points: 15,704, Level: 80
Level Up 71% Completed
FF Reputation: 62 sutyak Excellent Standing Member
Buy-Sell-Trade Rating: (16)
What I've been up to lately:
- Installed an Innovate LC-1 wideband with square led display.. still figuring out some issues though.
- Moved the vac source of my boost gauge. Now it reads vac and boost.
- Wired up the lights for my gauges because I couldn't see them at night.
I spliced into the dimmable wires of the hvac controls so they dim with the rest of my lights.
- Added a 3" cheapo Summit Racing glasspack (also another thread).
Didn't do much, if anything, to lessen the drone.
I DID however refab the pipes going over my rear crossmember so there are NO more exhaust rattles!
- Routed my catch can vent filter down near the air filter. No more stinky hvac!
- Wrapped my downpipe
Upcoming plans for the next year:
- SPEC stage 3 clutch.
- Torsen Limited Slip Differential
- Something to cure wheel hop.. maybe poly mounts or a torque strap.
- Shorten (cut/weld) wastegate actuator rod to preload spring for even earlier spool
- Stiffer rear springs (has nothing to do with the turbo)
PICS
Innovate LC-1 unit:
LC-1 grounds:
LC-1 display.
No it should not read 9.9 after warmed up and running.
If you know why it does please tell me.
EDIT: Fixed. Had to set voltage-to-AF numbers in LC-1 unit for analog out 1.
Inside of a Summit Glasspack:
Random turbo pic:
Downpipe:
mark
'04 Mach 1. Built. Turbo. 667whp/631wtq
'06 Focus. Built. Turbo. WMI. (sold)
'03 Mach 1 : 12.61 @ 106.59 (sold)
sutyak is offline
