Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Central locking problems - Finally a solution!
Old 09-01-2007, 09:16 PM   #4
exsodius
Fan#: 14827
What I Drive: 2014 Candy red Titanium
Points 13,017, Level 74
Points: 13,017, Level: 74 Points: 13,017, Level: 74 Points: 13,017, Level: 74
Level Up 42% Completed
Level up: 42% Level up: 42% Level up: 42%
Forum Activity 5%
FF Reputation: 1 exsodius Good Standing Member
Originally Posted by S0C0nFused View Post
The window 'edge' is not a water tight seal. It is designed to encourage water to channel away. That being said. If you are getting a lot of water inside the door (and it looks like you are) then that is a problem only solved by having the strip replaced OR there is also the possibility that the window guides are worn so that the window is no longer snug against the strip. Does your window bind at all when your raise/lower it?
It looks like the water strip is binding closely to the window. Exept for 1 inch at the rear part of window have a tiny clearance. But even where the strip looks tight, i can see water going trough it watching it from the inside.
It might be my fault because in the winter i am very lazy scraping ice of my windows. I push the window down button instead, using my weather strip as a ice remover . So maybe its this habbit that causes the strip wear down?
Ford Focus wagon 2014 1.0 Ecoboost 125 hk Candy red
exsodius is offline
