Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Central locking problems - Finally a solution!
Old 09-01-2007, 08:39 PM   #3
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
The window 'edge' is not a water tight seal. It is designed to encourage water to channel away. That being said. If you are getting a lot of water inside the door (and it looks like you are) then that is a problem only solved by having the strip replaced OR there is also the possibility that the window guides are worn so that the window is no longer snug against the strip. Does your window bind at all when your raise/lower it?
S0C0nFused is offline
