Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How are people cleaning their throttle bodies?
Old 08-08-2007, 08:37 PM   #5
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
Points 2,878, Level 32
Points: 2,878, Level: 32 Points: 2,878, Level: 32 Points: 2,878, Level: 32
Level Up 86% Completed
Level up: 86% Level up: 86% Level up: 86%
FF Reputation: 9 drjkel Good Standing Member
OK - The answer is it's a gasket not an o-ring. Thank you, Ray. That means no removal without a new gasket on-hand. Stock throttle body by the way. The "sheet metal" screws into only the plastic of the intake manifold make this a higher risk endeavor than one would want.
The rest of the engine is real clean. I see this on the Taurii also. Something about the pressure drop at the throttle plate preferentially deposits crud there.
I have used the Gumout throttle-body cleaner (NOT CARBURETOR CLEANER) with success. *Your results may vary*
drjkel is offline
