Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - sporadic's Turbo Duratec build thread
Old 08-07-2007, 11:18 AM   #66
Ted B
Fan#: 49312
What I Drive: 2003 EVO 8, 500whp / 1986 Must SVO
FF Reputation: 1 Ted B Good Standing Member
Originally Posted by sporadic View Post
I'll be performing a pressure test on my IC piping soon, and I'm also looking for a new wastegate actuator.
It takes longer than 4k to hit full boost.. more like 6k, so I know there's an issue.
I'll keep everybody updated on what I find.
I'm also looking into a wideband, probalby the Innovate LC-1.
The Innovate LC-1 is an excellent, accurate wideband O2. It's what I use, all I use.
The easiest means of pressure testing the intake system is right at the mouth of the turbo, using an appropriately sized silicone coupler and PVC pipe cap, with a quick connect fitting screwed into the cap. With a bit of compressed air and a slow twist of the regulator, it's easy to hear any leaks whistling.
If you're losing that much pressure, you'll most definitely notice a difference when you get it resolved. With that turbo, you should be getting full boost by ~3k rpm.
2003 Mitsu EVO 8 - 500whp
1986 Mustang SVO - Work in progress . . .
Ted B is offline
