Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - no harmonic dampener?
Old 08-03-2007, 08:01 AM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 66,880, Level 100
Points: 66,880, Level: 100 Points: 66,880, Level: 100 Points: 66,880, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
"Internally Balanced" = All balancing is done with in the (rotating Assy) crank rods and piston
"Externally Balanced"= Some balancing of the rotating Assy is done with counter weights in either or the Fly wheel or Balancer
If the engine is internal or external " balanced " has NOTHING to do with removing the only devise there is to help controle harmonics
Even if (and it isnt) the Zetec was externallly balanced and you removed it and replaced it with a solid (rubber removed) externally balancer you would still be removing the only way the engine has to controle harmonics
Were talking Harmonics here not the balance of the engine, Harmonics is VERY deadly to an engine and if Ford Enginers felt it was needed to go after groceries what do you think happens when you mod it and create higher RPM , Load... exactly you create more Harmonics
Its called a "harmonic balancer" to balance the engines harmonics NOT the engines rotating Assy
Again where did you get this info?
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is online now
