Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Need good wheel studs/lugs
Old 07-23-2007, 11:02 PM   #6
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,640, Level 78
Points: 14,640, Level: 78 Points: 14,640, Level: 78 Points: 14,640, Level: 78
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 90 goinloco1 Excellent Standing Member
Originally Posted by macdiesel View Post
goinloco1, would you recommend the kyokugen lug nuts with stock studs? If not how difficult was the arp stud install?
wouldn't recommend the stock studs for any type of racing period. once you get the arp studs and whichever open end nuts you prefer, replace a lugnut with a new one, hand tight is fine, you'll see what i mean about thread engagement. and its worse with some aftermarket wheels that have a thick hub flange.
studs are actually not hard to replace , i did all of mine on the svt with just the wheels off. make sure you have a stack of washers or an oversize nut, then use an old lug nut to pull the stud in when you tighten it.
i'd also recommend checking the tightness several times, about every 25-50 miles, to make sure they fully seat. and torque them, don't just crank them down
goinloco1 is offline
