Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Crane Cams - SUMMER SAVINGS!
Old 07-13-2007, 02:51 PM   #1
nthcoastcom
nthcoastcom's Avatar
Fan#: 7017
What I Drive: 96 SVT Cobra, 07 GT
Points 6,609, Level 53
Points: 6,609, Level: 53 Points: 6,609, Level: 53 Points: 6,609, Level: 53
Level Up 30% Completed
FF Reputation: 9 nthcoastcom Good Standing Member
Buy-Sell-Trade Rating: (21)
What is included?
04-05 Focus Duratec 2.3L
224-0010-Good Low End & strong mid-range. Works with auto or manual transmission. Smooth Idle. Recommended Air Intake and cat-back exhaust. Use with stock or aftermarket valvesprings RPM Range Idle - 6,000
224-0012- Excellant mid range profile. Good everyday 5-Speed Focus Cams. Slight lope in idle. Requires air intake, header and catback. MUST use Spring and Retainer Kit(also part of GP part # 903-2007) RPM Range 1,500-6,500
903-2007 2.3L Duratec Valve Spring and Titanium Retainer Kit. Can be used with 224-0010 cams & REQUIRED to be used with 224-0012 cams
00-02 Focus Zetec DOHC 16V 2.0L
223-0010-Good low end and strong mid range power. OK for automatic or manual transmission. For MAX HP gain use low restriction air intake and exhaust(header + catback). RPM Range Idle - 6,500
SOLD OUT OF STG2 Zetec Cams
PRICES
Camshafts $259.95
Duratec Valve Spring & Retainer Kit $179.95
Optional Items:
Duratec Air Intake $206.96
Zetec Air Intake $161.96
Fel-Pro Zetec Valve Cover Gasket Set $27.00
Extra Special deal on Magnaflow or Ford Racing Cat-back if purchased on same invoice
Delivery:
ALL CAMS ARE IN STOCK AS OF JULY 13, 2007
What you need to do:
Call, e-mail, PM or Post Here.
If you have questions/comments please post them.
nthcoastcom is offline
