Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - For Sale: 05-07 2.3L Throttle body and Throttle Position Sensor
Old 07-05-2007, 05:25 PM   #1
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
Points 4,258, Level 41
Points: 4,258, Level: 41 Points: 4,258, Level: 41 Points: 4,258, Level: 41
Level Up 54% Completed
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
Throttle body is not ported and has 40K miles on it. Still in great condition, and freshley cleaned.
Throttle position sensor is in perfect working order and also has 40K miles on it.
I am selling the TB because I have the Cosworth 67mm. When I installed the aftermarket TB, there was a problem with the engine not idling down like it should while coasting in neutral. This was because I had the screw adjusted to where the throttle plate was sitting barely open. I thought the problem was the TPS, so I replaced it. Then I found out the problem was not the TPS, but the screw on the TB itself just needed to be adjusted. After that, everything worked fine.
Looking for $50 shipped for the throttle body and $18 shipped for the TPS.
Both parts will fit 05-07 2.3L Duratecs
afraziaaaa is offline
