Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - fuel return set-up
Old 07-03-2007, 07:23 AM   #52
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 67,730, Level 100
Points: 67,730, Level: 100 Points: 67,730, Level: 100 Points: 67,730, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
DO NOT cut to get to the fuel tank with the fuel tank in place at least take the straps down and cut it if not remove it all the way
This is an easy way to get a return fuel system, it worked on mine for a long time , with this set up you can easy replace the stock pump with a 255 LPH walbro
This isnt for everyone to do and any time your working around GAS you need to be VERY CAREFULL
The only Diff between how I figured this out and whats on mine and his , Is that I have a 255LPH walbro and no B-A-P
I dont think his B-A-P is needed but the fuel PSI will need to be watched to find that out something I guess I should of looked into why it was on the dyno
Dont cut corners or cost on this use good stuff and make sure you use EFI fuel hose in the tank regular fuel hose wont hold up A carb regulator will not work it must be a EFI regulator
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is online now
