Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - REGISTRATION OPEN!! Summit Point August 4-5
Old 06-27-2007, 08:26 PM   #9
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Originally Posted by miniboon View Post
From the site:
All cars must be inspected before the event at a dealer or independent shop, and you must bring the signed or stamped safety inspection form to the event.
I'm just wondering what type of inspection I need
It is more comprehensive than just a trackside inspection. You must take a copy of the tech inspection form to a qualified (ASE) mechanic and have them look at the car. They look for the following:
ENGINE COMPARTMENT ok fail REAR SUSPENSION ok fail
Accelerator linkage bushings/springs ___ ___ Axle shafts/boots ___ ___
Air filter bracket, mounting ___ ___ Shocks/leakage/rubber bushings ___ ___
Battery frame/hold-down ___ ___ Springs/center spring ___ ___
Battery/cables ___ ___ Stabilizer/bushings ___ ___
Engine clean ___ ___ Subframe/mounts ___ ___
Engine mounts ___ ___ Tire wear not less than 3/32 ___ ___
Engine oil/fuel leaks ___ ___ Trailing arm bushings ___ ___
Belts ___ ___
Visco clutch ___ ___ DRIVE TRAIN
Water pump/water hoses/clamps ___ ___ Center Support ___ ___
Water leak ___ ___ Flex disc/universal joint ___ ___
Transmission mount ___ ___
FRONT SUSPENSION
Ball joints/bushings ___ ___ BRAKES
Draglink/tie-rods ___ ___ Brake booster ___ ___
Idler arm bushings ___ ___ Brake calipers/cylinders ___ ___
King pins-no play ___ ___ Brake discs/drums ___ ___
Shocks ___ ___ Brake fluid renewed ___ ___
Springs No spring spacers ___ ___ Brake hoses/brake lines ___ ___
Stabilizer bushings ___ ___ Master brake cylinder ___ ___
Steering box, lines, leaks, play ___ ___ Brake pads/shoes-min. 50% for
Steering shock/coupling ___ ___ 1 driver; 80% for 2 drivers ___ ___
Subframe mounts ___ ___ Brake dust shields removed ___ ___
Tire wear-not less than 3/32 ___ ___
Tires-no cuts, bruises ___ ___ EXHAUST SYSTEM
Wheels-bearing play/damage/Bent/correct lugs ___ ___ Exhaust leaks ___ ___
Exhaust system secure ___ ___
OIL LEAKS UNDER CAR LIGHTS/SEAT BELTS/WINDOWS
Engine/transmission ___ ___ Signals/stoplights/headlights ___ ___
Rear end/differential ___ ___ Seatbelts/windows operation ___ ___
It's all subjective to a degree. Trackside, they check the lugnuts again and that's about it.
Not really a big deal. The Benz club insurance policy requires the formal inspection.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
