Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New sympton with an old problem that no one can fix..
Old 05-15-2007, 12:51 AM   #7
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 15,200, Level 79
Points: 15,200, Level: 79 Points: 15,200, Level: 79 Points: 15,200, Level: 79
Level Up 70% Completed
FF Reputation: 90 goinloco1 Excellent Standing Member
easy fix on the svt you can do yourself for about 15 bucks. ive found on alot of svt's its the engine grounds.
go to a stereo store and pick up 10' of 6 gauge fine strand power wire,4 solder on ends with a 3/8 inch hole in them (these are used under the points on the block shown), 2 with a 3/16" hole (mount 1 to each fender under an existing ground point), and 2 with a 1/2" hole (mount under nut on battery negative clamp).
for grounds its not necessary to heatshrink or tape the ends, other than to make them look better. at each mounting point make sure it it clean and has metal to metal contact. hardest part is measuring and soldering. which really isnt hard
goinloco1 is offline
